Tell me your times....
  • #16
    I doubt you'll get into the 13s. The Fieros with DOHC swaps are landing right at flat 14s, and that is with about 220hp, and the power curve of the DOHC. But definately expect low 14s, and who knows, maybe you can break that barrier.[/quote]
    But arent the DOHC'c engines heavier?And most of them are going in the already heavier GT(fastback) models.The coupes are almost 200 lbs lighter out of the factory with the standard 2.8 so I should pickup some time with the notchback. Maybe I can get to the high 13's.
    • #17
      Yes they are, by about 50lbs or so. Most are going to be in the fastbacks(mine will be). You might be able to, it really is hard to say. I'm sure traction will be an issue as well.
      • #18
        Originally posted by bszopi
        oh yeah...rub it in why don't you...."Really Slow Cars"...pffft
        90 Grand Prix LE 2dr
        3.1L - 4T60
        177k
        • #19
          15.015 @ 94 mph, and 15.4 @ 98mph. I have no traction. 291 lbs/ft of torque is to blame.
          3.1L \'88 Camaro - 16G @ 9.5psi
          222/291 @ wheels
          T61 on the way!
          • #20
            went a 14.66 @ 94.15 MPH with a 3.2/3100 hybrid
            for details http://www.v6z24.com/registry/z24dawg
            thats with stock 3100 heads, going to run fully ported and polished heads in 05
            probobly looking at 160 hp at the wheels or so
            3200 Hybrid 9.317 @ 77.87 mph, 14.343 @ 95.54 mph N/A on street tires
            99 Grand AM SE1 3500 V6
            • #21
              Originally posted by Jeff420
              my best run was 9.32 in the 1/8th mile in my 4 door 96 grand am. i should be running a 15 or so in the quarter. 2 1/2 inch kink bent pipes(yuk), cai, and a wet 75 shot.
              9.32 in the 1/8th usually equates to more like a 14.6.14-7ish 1/4 mile ET.
              Matt F.
              TGP 1/4 mile times
              http://photobucket.com/albums/y33/mfewtrail/
              1990 TGP Coupe VIN Database
              • #22
                car: 94 lumina 4 door euro
                engine: 3.1 mpfi
                trans: 4T60-e
                1/4 time: 18.1@71mph
                guess why i have a 3400 now
                • #23
                  '89 Turbo Grand Prix with the following mods:
                  -Jeff M. X-over
                  -K&N filter
                  -DSM BOV
                  -getrag 284 with stock clutch
                  -modifies chip to work with 5 speed with around 11 psi of boost
                  Everything else is stock, right down to the 128,000 mile catalytic converter.
                  14.643 @ 96.89 with a 2.258 60'
                  \'89 Ciera Int. Coupe
                  \'89 TGP
                  • #24
                    Originally posted by The_Raven
                    All of this in my '85 GMC Jimmy, running, with traction problems and fuel delevery problems, a 13.8 @ 99.
                    You should get some 'Caltrax' style traction bars as they work great. My brother in his 3800 SII S-10 was having series traction issues with 245/50/16 tires so we made up some 'Caltrax' style traction bars for him. He went from a 2.5 without to a 2.0 with on street tires. I think you can pick up a set for around $150, but we just made our own.
                    \'89 TGP
                    • #25
                      Your formula will maybe see mid 14's...not mid 13's like stated earlier.
                      1984 Indy Fiero 3.4L
                      13.7 sec @ 98 mph
                      *ALL THROTTLE AND NO BOTTLE*
                      • #26
                        i guessed 15 because someone else with mods similar to mine ran around that time. Id rather say im slower than i really am than vice versa
                        • #27
                          84 cavalier stock 3100 5spd 9.3:1 compression, 2" exaust, 1984 suspension... best on slicks was a 14.30
                          best on street tires for this year was 14.96@ 91 and second best was a 15.02@ 93
                          14.96@91.47 in the 1/4
                          9.63@74.36 in the 1/8th
                          • #28
                            I have a '90 Grand Prix STE Sedan w/3.1L Turbo. Mods in my sig. I have ran a best of 14.695 @ 94.49 at the track, but this was before my cam/topend/ud pulley. With the current setup, I have G-tech times reporting 13.9's, but that is untuned and with a 2.2 60'. With some tuning, larger fuel injectors, and some traction, I believe its a 13.6-13.7 second car, but thats just a guess.
                            However, I only have proof of a 14.695 at the time.
                            Shawn
                            99 Grand Prix GT
                            • #29
                              from what i hear those g-techs are pretty accurate usually only saying that your about a 1/10-2/10 of a second faster than you really are.
                              • #30
                                Well, it all depends on how well you calibrate it, and if you're on flat road, etc.. When the car was stock I pulled a 15.334 on the G-tech, but at the track I went 14.968 with the exact same setup. (except I dropped tire pressure a little and pulled out the spare tire & jack). But it is pretty close.
                                Shawn
                                99 Grand Prix GT
