Tell me your times....
  • Tell me your times....
    I'm looking to get a sense of what to expect from our pushrods engines.I'd like to see some 1/4 miles times posted with the type of car,engine mods, and est HP... Ok it braggin' time......
    Thanks everyone
    Motor - 3.1L V6
    Trans - 5 speed
    Dyno'd - 123 hp 168lbs of torque
    Mods - 2.5" manfold back manderal bent exhaust with no cat dumped out the side
    1/4 times - consistant 15.6 - 15.7's
      Best times are in my Sig. The street tyre time is outdated, I only made passes with slicks after i changed to the Holley ECU, 22# injectors, the Larger T/B, and the solid mounts.. So I *Could* be faster? maybe. dont know.
      The fastest time on slicks is the first 660 Jbody in the 13's (yeah its braggin' time) :P
      92 Sunbird GT, 3.1L 5spd Manual.
      Mods, TOO much to list, Read this: http://www.j-body.org/members/colin/cars/1/ Its old in terms of my updating the Pictures (2-3 years old now) and the Timeslips on the page. but the specs on the car are all up to date i think.
      Colin
        12.31@113.xx (I'd have too look) on 12 psi. Still have some work too do, sure I can get it too do better. If I had too guess (since I do not actually know the HP), knowing the weight, using the trap speed, it comes too around 360 wheel.
        Curtis
        91\' Turbo Z24
        http://www.turboz24.com
          my times are in my sig.
          3.1/3400 hybrid
          like Colin, my street tyre times are outdated, being before upgrades like new ears and whatnot.
          going by 1/4 mile time estimators, that's 190 hp at the wheels.
          1989 Z24 3.1/3400 hybrid
          14.13@96.69 N/a slick full interior
          maybe my \"dreams\" should be a little higher :P
            3.2L hybrid....
            GenI block, gen II 3.1 crank, Federal Mogul Hyper pistons, for a 1990 Cavalier (.030"), GMP Bumpstick, same as Crane 260-2, '95 3100 top end, essentially stock, custom headers, turbo, intercooled, and a few other things that I'm probably forgetting. All of this in my '85 GMC Jimmy, running, with traction problems and fuel delevery problems, a 13.8 @ 99. Check out http://www.v6z24.com/registry/Six_Shooter/ for more info and pics.
            I have dyno sheets that show 218HP and 270 ft/lbs at the rear wheels. I am hoping to anihilate those numbers in the coming year, with a larger turbo, nitrous intercooling and a few other upgrades, I'm also hoping for a high 12, with the rectified fuel delivery and traction problems.
              13.7 @ 98mph on 390cfm carb and edelbrock intake iron head 3.4L
              Looking to dip into 12's with gen3 swap and turbo.
              1984 Indy Fiero 3.4L
              13.7 sec @ 98 mph
              *ALL THROTTLE AND NO BOTTLE*
                low 17s if i'm lucky
                i'll get some real times this spring...but by then i may have a few mods up my sleeve
                90 Grand Prix LE 2dr
                3.1L - 4T60
                177k
                  16.5. Heavy truck, plywood like aerodynamics. Wheelhop like a bitch too. If I solve the wheelhop maybe 16.3 or so.
                  Its time for an LS1
                    It needs to be updated, but...
                      Well this is encouraging. I am going to have roughly a 2600 lb 88 fiero 5spd with about 185-200 hp. so I should be in the low 14 to high 13's right?
                        well i have an 03 3400 pretty much bone stock in an 89 beretta 5spd 14.598@93.27
                        look at sig.
                        89 BerettaGT 3400 5spd
                        60' 2.106 street tires
                        Best ET 14.313@95.37 N/A
                        Now Boosted
                        14s@109 (poor tune still rich, poor driving skills, poor owner)
                          More like mid to high 13's
                            I doubt you'll get into the 13s. The Fieros with DOHC swaps are landing right at flat 14s, and that is with about 220hp, and the power curve of the DOHC. But definately expect low 14s, and who knows, maybe you can break that barrier.
                              my best run was 9.32 in the 1/8th mile in my 4 door 96 grand am. i should be running a 15 or so in the quarter. 2 1/2 inch kink bent pipes(yuk), cai, and a wet 75 shot.
