Crane cam input???Needed
  • Crane cam input???Needed
    I was looking and found that crane offers a Powermax cam for the 60*.Can they be used with teh 3100 ?
    they are
    258/264 .401/.423 1000-4000 rpm
    or
    264/274 .423/.423 1500-4500rpm
    anyone running one of these?What is your opinion?Are there any alernatives?
    Thanks
    There are (at this current time) no aftermarket cams that can be used with a 3100/3400.
      Yup all cams out there will only work on flat tappet motors. Wait for Comp they are apparently working on some.
        You can install the flat tappet cam and lifters in the genIII block, you will need new pushrods, and a genI/II timing set however.
          you can put the gen 2 cam and lifters in a gen 3 block
          thats what i am doing
          but......what about the cam sensor for the SFI
          I Like V660s
          Does Chevy make beer
          ~Jayme~
            Fuck it. Flat tappet cams are a step backwards. Just wait a few months.
              you could get your stock cam reground to those specs. you will likely need custom length pushrods though. or you could take the step back to gen 1/2 stuff, and put in a nice solid roller cam, that would be way better for power then a gen 3 hydralic roller, but requires more matinance.
                betterthanyou is right, don't back step.
                At least stay with roller tapets.
                I say wait for comp or do a regrind.
                Seth
                Camaro 1
                85\' 3.4L, T-5, 3.42gears
                Mods at work on,
                car domain site 03/13 Saab intercooler flow numbers.
                85\' IROC Z28 Ttop 5.0L, auto mostly stock.
                  If you want, I know where you can get a custom roller cam for a 3100/3400 right now for 400.
                  Curtis
                  91\' Turbo Z24
                  http://www.turboz24.com
                    I am not in a really big hurry.I am in the process of a 3100 swap and if I could I'd like a cam change.400 is a little out of my range though.Has nayone heard anything about the comp cam progress?
                      where can you get a custom roller cam for 400
                      are you talking about one with or without the cam sensor marks
                      I Like V660s
                      ~Jayme~
                        Well, if you are serious I can get you the info. I just don't want a lot of people asking them if they can have one, then backing out. I'd have too ask, but as far as I know it's a direct billet copy of the stock 3100/3400 cam. Not sure if they have it with both style cam sensor wheels, though. Just directly email me turboz24@swbell.net
                        Curtis
                        91\' Turbo Z24
                          well i wasnt really needing one
                          i have an OBD1 computer running mine so i can just get one custom ground without haveing to worry about the cam sensor
                          thanks though
                          I Like V660s
                          ~Jayme~
