Ok, I was thinking about cams after I get a chip and top end swap, most likely the 272 cams but I hear 260 cams can be just as good, but which would benefit a 3000lbs 92 2dr Grand Prix with a pushrod to get it down a drag faster?
"Cam race"
I would definately go with the 260. That or the comp 260. A 272 would be too aggressive for what you want, your lowend would die. I like my 260 cam. And just so you know, unless you've done a lot of weight reduction, your car weighs significantly more than 3000lbs.
Shawn90 Grand Prix STE 3.1 Intercooled Turbo-3100 Hybrid
99 Grand Prix GT
Re: "Cam race"
Originally posted by PrixOk, I was thinking about cams after I get a chip and top end swap, most likely the 272 cams but I hear 260 cams can be just as good, but which would benefit a 3000lbs 92 2dr Grand Prix with a pushrod to get it down a drag faster?
With my 5spd i rev my Comp, 260/260 212/212 duration cam all the way up to its limit of 6200 rpm, the 272 would want even more RPM for full potential, the sad part of auto's is its hard to get valve'd/programed to shift at those RPM's. (well for the 3t40 it is, dont know about the 4t60)
the other problem is i'd recommend the smaller 260 series cams as if your GP is still using the GEN2 3.1L MPFI top end, you are not really going to be able to take full benefit of the larger 272's potential with the gen2 intakes restricting the airflow alot at Higher RPM.
the 272 Needs High compression as well. and is not so emissions friendly as well.Colin
135H
270
270
218
218
.460?
.460?
110
.000?
.000?
42328
http://schneidercams.com/cams/34.
Also solid cams..........1992 Chevrolet S10
2.8 v6 tbi 5 speed
Originally posted by 614streets
this should work now: http://schneidercams.com/cams/34Colin
Re: "Cam race"
Originally posted by v6h.o.the other problem is i'd recommend the smaller 260 series cams as if your GP is still using the GEN2 3.1L MPFI top end, you are not really going to be able to take full benefit of the larger 272's potential with the gen2 intakes restricting the airflow alot at Higher RPM.
99 Grand Prix GT
I have an old article in Car Craft showing a 15HP gain in an 80s 2.8 V6 with the 272 cam. I agree with the others about the auto trans, if you have the auto then stick with the 260 but if you have the stick go with the 272. It really doesn't need higher compression to work right, as the old article shows and, being a split pattern cam, it really doesn't hurt lowend as much as you might think. You're much better off with a split pattern cam than a single pattern for this reason.
Obviously it will work better with porting but the rpm requirement isn't much higher than the 260 cam. At most, according to the Crane catalog, it's only 500 rpm more than the 260. The rpm range the 272 starts to make power is also higher (2k) so it's obviously best for a stick where as the 260 would be better for an auto.
The article was done on a 2.8 V6 in a Fiero with it's stock MPFI and iron heads btw.Activities Director
N.I.F.E.
88 Fiero formula 5-speed.
modded 2.8 pushrod...for now.
www.fierofocus.com
It means the duration on the intake and exhaust lobes are not the same. Single pattern cams use the exact same lobe pattern on both intake and exhaust. The split pattern cams tend to have broader power/torque curves.
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
BTW just to clarify; when I said the 272 cam starts making it's power at a higher rpm and stated 2k, I meant the 272 starts making it's power in the 2k range not that it started 2k higher. The 260 starts at 1500 rpm.Activities Director
N.I.F.E.
www.fierofocus.com
