Testing the 3500 Plenum.
  • #16
    ah i see. but with the shorter runners won't that hinder the lower end then if it aids the upper?
    1996 Chevrolet Monte Carlo LS/SS 3100 SFI
    T.B. coolant bypass - RedZ intake - MAG-XTS wires w/ AC Delco Platinum plugs - DHP PCM - 3400 SFI TB - GM front strut tower brace - FFP UD pulley - OD alt pulley - Viper 791XV Protection
    • #17
      yes, but you can't have the best of both worlds with just a single mod. If you design the who;e engine around it, then you can have good low end with increased top end.
      • #18
        *adds to his wishlist*
        90 Grand Prix LE 2dr
        3.1L - 4T60
        177k
        • #19
          kinda looks like the top of a 2.4l 4 banger
          1994 Oldsmobile Achieva (2002 3100 SFI)
          Homemade ram-effect CAI
          K&N cylinder filter
          Poorboy Lowering Kit
          Front STB
          • #20
            does look sorta like the cover on the 2.3 Quad 4/2.4 Twin Cam
            3.1L - 4T60
            177k
            • #21
              How much do you think this is going to gain? Would it be worth swapping? And also, you have to have the 00+ 3100 or 3400 LIM for it to work right? You can't use the older 3100 LIM. I'm thinking about buying a 3.1 Lumina from a friend, and I'm trying to debate whether I should use a 3400 topend or if it would be worth the extra $120 to use the 3400 topend with 3500 plenum. Ideas?
              Shawn
              99 Grand Prix GT
              • #22
                damn i think ill just stick with getting the ported 2000+ 3100 plenum when i do my swap
                unless you really gain alot from it then fuck doing all that extra work
                I Like V660s
                Does Chevy make beer
                ~Jayme~
                • #23
                  Thats what I'm thinking. It doesn't look like its worth the small gains it MAY give.
                  Shawn
                  99 Grand Prix GT
