head gasket to lower compression
  • head gasket to lower compression
    I have been thinking about using a thicker head gasket to lower my compression by about .5 or so, but I have heard that this is a bad idea. Is it true that this shouldn't work or did people just make this up? Also explain why it's not a good idea if it's not.
      what engine do you have? iron head or Alum head?
      the Iron head engines used a .040 compressed thick gasket, and the Alum heads used a .060 compressed thickness gasket. IF you have an iron head, using an iron headed gasket would do the trick for a small decrease in CR.
      otherwise you're looking at something custom
      I run the opposite in my car i have Iron head gaskets on mine to lower my CR due to im n/a.
      Colin
        Don't you mean RAISE your CR? :P
        Marty
        '99 Z-28 - Weekend Driver
        '84 X-11 - Time and Money Pit
        Quote of the week:
        Originally posted by Aaron
          Last page of this, copper head gaskets for GM 3.4L V6.
          I have an aluminum head motor. I thought stock head gasket for aluminum head was .43" but I'm usually wrong and must have gotten it confused with iron heads.
