From the looks of Pics I've seen, the upper plenum on the '99 and up 3400 would bolt on backwards. has anyone tried this before. I dropped the DOHC plans, and am after a 3400 for my spitfire. My throttlebody HAS to come from the other end, for my laterally mounted engine.
Reversing the Upper Plenum on a 2001 3400?
Your right, the lower would have to be turned also. It's funny, the picture of the complete Motor/Tranny setup doesn't show the swap, but the close-ups do. I bet thats gonna be an electrical funhouse. But I geuss all I would have to do is plug the injectors in for their prespective spot.
Originally posted by TheProfessori thought the water pump attached to the LIM on 3X00 engines-Brad-
I will be using the Killerbv6 timing cover, along with they're water pump. It's expensive, but necessary. It uncovers the motor a little, kinda gives it a Micro-V8 look. After I cut, grind, and re-weld the original 3400 exhaust manifolds to fit my triumph, hopefully I can find some sidepipes that will bolt up. About the only thing I haven't figured out is the correct clutch for combo of #1-94 2.2l 5sp bell, #2- 85 mustang t5 w/ 10 spine input shaft, and #3- still using the hydro-clutch.
Originally posted by betterthanyouOne from a 60* V6 S-10 will do the trick for you. I dont think the T5's had different input shafts.
I think what I'll try to do is find a t-5 from the 94 or 95 that was stock for that bellhousing, that way, I can use the stock clutch parts. All I will have to do then is have the flywheel bolt holes matched to the new clutch by a machine shop. AND, make sure I've got the right pilot bearing...........Sound Good?
Originally posted by The_RavenOriginally posted by betterthanyouOne from a 60* V6 S-10 will do the trick for you. I dont think the T5's had different input shafts.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
My concern is the spline count. The teeth in the clutch plate must match the spline of the input shaft. I have read that the 80's and early 90's input shafts used primarily 10 spline shafts. They were alledgedly shorter than they're '93 and up counterparts. I read somewhere that ford went back to a longer shaft at some point, or some applications. I have never seen one, so I don't know for sure. That's just what I've read in the last few months, researching this 3400/spitfire swap.
