Iron Head 2.8 Intake on a Gen.2 3100 Motor?
  • Iron Head 2.8 Intake on a Gen.2 3100 Motor?
    I was wondering, can I put the Edelbrock Intake designed for the early 2.8 RWD motors, on a 1996 3100 aluminum headed motor. I have a MegaJolt Lite Jr. setup that would give me spark. If the Edelbrock intake can be made to work, I'll buy a water pump-less timing cover and put it in a lttle go gart I have!.................Quintin
    Nope, sorry. The gen1 iron heads are completely different from the gen2/3 aluminum heads, so the intakes are not interchangable.
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      Damn the Bad Luck!
        Well then, I don't suppose I could bolt a set of 2.8 iron heads onto my '96 3100 block?
          Not unless you also swap for some 3.1 iron head pistons from a Lumina APV, Isuzu Rodeo, or Camaro. The combustion chamber volumes and piston dishes are different, so the compression would be too low.
          Marty
          Quote of the week:
