5.0 heads Ive done
From the 5.0 heads you can get an Idea on how
the casting is removed in the cc chambers ( harder with cast iron) and polished.
Get the Standard Abrasives Polishing kit and A DELUXE KIT.
The exhaust ports are where you want to do most of your work.
After porting them on the high side and then the passageway polish them up just like the cc chambers.
On a N/A 272 cam engine you dont need to do too much grining in the runner
and the finish should be left semi rough to aid in atomazation. But you should do some grinding
in the bowl under the valve seat.
When you buy the Standard abrasives kit it will include detailed instructions. Hint Hint.
Just dont grind the hump in the intake to much, you can shape it a little bit and small cartridge roll the sides and four conrners.
Lastly gasket match the intake and cylender head runners.
The top heads are from a 2.8 but are on the wild side. Look how big the exhaust ports are. Youd need at least a 1 5/8" primary to work with that.
Dont go wild , and research techniques.
