Dishes, Domes, Compression Heights and Chamber Volumes
  • Dishes, Domes, Compression Heights and Chamber Volumes
    I'm trying to assemble some tabular data for the purpose of future assembly of mongrelized engines. Anyone care to help?
    So far, using data from this thread: http://www.60degreev6.com/index.php?...iewtopic&t=310
    I have assembled the following table:
    Code:
    Application     Dish/Dome     C/H
    2.8 LO          0 cc's        1.578
    2.8 HO          0 cc's        1.599
    3.1             12 cc's
    3.4             8 cc's
    2.8 Gen2        21.2 cc's     1.608
    3.1 Gen2        26.4 cc's
    3100
    3400
    TDC
    DOHC
    Head     Chamber size
    Gen1
    Gen2     28 cc's
    Gen3     ~28 cc's
    TDC
    DOHC
    Misc: Gen2 stock head gasket: 0.060
    Gen1 stock head gasket: 0.040
    Please feel free to make corrections/additions as necessary.
    RacerX11, what's the source of the info you used in that thread?
    What were the C/R's of the iron head 3.1's and 3.4's? It doesn't make sense for the 3.4 to have more displacement and a smaller dish unless it had higher compression, which I don't really accept as reasonable yet.
    Current:
    \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
    \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
    \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
    Gone, mostly forgotten:
    \'90 Pontiac 6000 SE AWD: slow but invisible
    I dug up pretty much all of that data from catalogs and other published specs for both stock pistons, Silvolite, Slealed Power/FM, and Mahle stock replacements, and actually measuring some pieces I had.
    I put a spreadsheet together several years ago to calculate different part combinations and compression ratios. There are some assumptions that aren't 100% acurate, such as the dish volume being an exact cylinder (they are actually curved at the botom), and I didn't include the volume between the top ring and the piston top. Both of this can account for maybe a 0.1 point or so compression difference.
    I think at one point we had this posted on the main site, but it might have got lost in the transitions. Here is a copy of the spreadsheet. You can play around with rod length, piston compression height, dish volume, head gasket thickness, etc. Feel free to modify it to be more accurate
    Marty
    EDIT: I removed this spreadsheet. See later post for more recent version of file.
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      Thanks. I don't have excel on this computer but I'll find somewhere to look at it.
      Current:
        3400 compresion is 9.6-1
        3100 and 97-99 venture 3400 compression 9.5-1
        3.1 compression 8.8-1
        sorced from Shop Key (Snap on) computer manual
          gen 1 heads are about 48cc
            Re: Dishes, Domes, Compression Heights and Chamber Volumes
            Originally posted by Will'sFiero
            Code:
            2.8 LO          0 cc's        1.578
            2.8 HO          0 cc's        1.599
            3.1             12 cc's         [b]1.450[/b]
            3.4             8 cc's            [b]1.457[/b]
            3.1 Gen2        26.4 cc's
            3100
            3400
            TDC             [b]4? cc's[/b]   [b]1.457[/b]
            DOHC         [b]should be about the same as above[/b]
            Head     Chamber size
            Gen1     [b]52 cc's[/b]
            Gen2     28 cc's
            Gen3     ~28 cc's
            TDC
            DOHC
            I added some stuff there. hope it shows up.
              double post
              What I added was supposed to be in html bold but it didnt' work.
              just look for ubb tags
                Code:
                2.8 LO          0 cc's        1.578
                2.8 HO          0 cc's        1.599
                3.1             12 cc's       1.450
                3.4             8 cc's        1.457
                3.1 Gen2        26.4 cc's
                3100
                3400
                TDC             4? cc's       1.457
                DOHC            4? cc's       1.457
                Head     Chamber size
                Gen1     52 cc's
                Gen2     28 cc's
                Gen3     ~28 cc's
                TDC
                DOHC
                Ok, thanks. I tried HTML bold, but that doesn't seem to work with the code tag either.
                I'm still puzzled about the relationship of the Gen1 3.1 and Gen1 3.4. What are the compression ratios of each? Does Gen1 3.4 actually have significantly higher compression than the Gen1 3.1?
                Do you have TDC/DOHC chamber volumes?
                Current:
                  According to my specs, Gen1 3.1 CR is 8.5, Gen1 3.4 CR is 9.6.
                  Marty
                  Quote of the week:
                    I did the calcs and came up with 8.43 and 9.5 which is close enough to those numbers (which I presume are published specs) to satisfy me.
                    Interesting that they ran the iron heads at 9.6 and run the Gen3 heads at 9.6 as well... one would think that they'd run the Gen3 heads at 10.6 or even a little more...
                    But that would only happen if GM gave a shit about the V6/60, which they've proven over and over again they do not.
                    Current:
                      I found a newer version of my spreadsheet that has some more accurate numbers, plus a little cleaner appearance. Also, there is a summary page with specs on all of the engines.
                      Here is the summary:
                      Engine | Bore | Stroke | Gasket Thickness | Piston Compression Distance | Dish Diameter (in) | Dish Depth (in) | Comp Ratio
                      2.8 Iron LP | 89mm / 3.504" | 76mm / 2.99" | 0.040" | 1.578" | 0.000 | 0.000 | 8.5
                      2.8 Iron HO | 89mm / 3.504" | 76mm / 2.99" | 0.040" | 1.599" | 0.000 | 0.000 | 8.9
                      2.8 Gen2 | 89mm / 3.504" | 76mm / 2.99" | 0.060" | 1.608" | 2.470 | 0.270 | 8.8
                      3.1 Iron | 89mm / 3.504" | 84mm / 3.307" | 0.040" | 1.450" | 2.950 | 0.106 | 8.5
                      3.1 Gen2 | 89mm / 3.504" | 84mm / 3.307" | 0.060" | 1.450" | 2.880 | 0.247 | 8.9
                      3100 | 89mm / 3.504" | 84mm / 3.307" | 0.060" | 1.470" | 2.880 | 0.230 | 9.6
                      3.4 Iron | 92mm / 3.622" | 84mm / 3.307" | 0.040" | 1.457" | 2.750 | 0.080 | 9.6
                      3400 | 92mm / 3.622" | 84mm / 3.307" | 0.060" | 1.460" | 3.000 | 0.233 | 9.6
                      3.4 DOHC | 92mm / 3.622" | 84mm / 3.307" | ?? | 1.457" | 1.000* | 0.080* | ??
                      *Note: Dish info for 3.4 DOHC is estimated. Rough number based on 4 valve reliefs.
                      Iron Comb. Cham. Volume 2.96 cu.in. 48.5 cc
                      Aluminum Comb. Cham. Volume 1.61 cu.in. 26.4 cc
                      Deck Height 8.82" 224 mm
                      Connecting Rod Length 5.7" 144.78mm
                      2.8, 3.1 Gasket Bore ~3.69"
                      3.4, 3400 Gasket Bore ~3.75"
                      Marty
                      Quote of the week:
                        Sweeet. Thanks. That fills in a lot of holes...
                        Got anything on TDC/DOHC chamber volume?
                        Current:
                          So the table looks like this now:
                          Code:
                          2.8 LO          0 cc's        1.578
                          2.8 HO          0 cc's        1.599
                          3.1             12 cc's       1.450
                          3.4             8 cc's        1.457
                          3.1 Gen2        26.4 cc's     1.450
                          3100            24.5 cc's     1.470
                          3400            27 cc's       1.460
                          TDC             4? cc's       1.457
                          DOHC            4? cc's       1.457
                          Head     Chamber size
                          Gen1     48.5 cc's
                          Gen2     26.4 cc's
                          Gen3     26.4 cc's
                          TDC
                          DOHC
                          Current:
                            Nope, sorry. Haven't started playing around with the DOHC yet. Other than the pistons, that is.
                            Marty
                            Quote of the week:
                              advertised cr of the gen 1 3.4 is 9.1 to 1
                              if its accually 9.6 then I need to get a bigger cam
                              and the c/h of the iron head 3.1 & 3.4 is backwards on the table...
                              the 3.1 is 1.48 and the 3.4 is 1.45( at least thats what the trw piston pages say)
                              1995 camaro 3.4 5-speed
