Well I tried a search but came up with about 200 results, so hopefully someone could assist me. I have the 3.1V6 and a know there is a later varient called the 3100. The 3.1 is rated at like 140hp max and the 3100 150-185 or something. I was wondering if anyone could tell me the difference between these to similar engines. Also I am about 30miles away from a junkyard where I could get many parts, so are there any easy interchangeable parts like the IM or anything? I don't really want to get to invovled with this car since I am saving up for a Tib. Thanks guys.
difference between 3.1 and 3100?
the 3.1L is the older Generation 2 family of engines.
the 3100 is a Gen 3 engine.
there are a huge amount of differences between them
3100:
different style heads, intake manifolds, exhaust manifolds
roller lifters/camshaft.
96+ 1.6:1 roller rockers.
cross bolted main caps
revised oiling in block.
ect ect ect.
parts can be interchanged but its an involved swap. its what we call a "hybrid"
there are heaps of posts involving the differences and what is needed to be used to build a hybrid. there is also info on main page on differences between blocks ect.Colin
TB won't mount up. I don't know why, but they swapped corners for the mounting bolts between the 3.1 and 3100. IOW, a 3100 TB would be turned 90º if you mounted it to a 3.1 plenum.-Brad-
