I have a 3.4 iron block that i put z34 pistons in. also the crank i am useing is a 2003 crank as i was told these were balanced much better.
I did a test on the clearance i had with piston top dead center and i got .3510 clearance from valve all the way up to valve touching piston.
My plan was to put a 272 cam in this engine alough it's lift is speced at .482 at exhaust will this cause collision of my pistons and valves?
is there a better way to test for this other then the way i did. also has anyone done this before and maybe could tell me from experince.
As you can tell i am not what you would call a veteran of engine rebuilds.
