does anyone have a solid lifter or solid roller cam in their 660??? im just starting with building my motor, and am still looking at cam choices. i know crower makes roller cams, and several other companies make solid lifter cams. i know there is more power to be had with a solid or solid roller, but matinance becomes an issue.
how often do you need to set valves on one of these for a street motor??? this is my main concers, as its not as easy as popping the valve covers off in my car (86 z24), the upper and middle plenum must come off, making setting valves a several hour job.
