Hey guys,
I recently bought a set of Gen III aluminum heads. (Casting Number 24503769) I want to use these on a 2.8 RWD engine. From everything that I've read, the heads should work... I hope. Has anyone here done a similar swap? Also, this engine will be in a race truck, so I'd like to run very high compression (11.5-12.5:1). Does anyone make an off-the-shelf piston for a 2.8 that will give that kind of compression with Gen III heads and a long duration cam?
TIA,
Adam
TIA,
Adam
