This is a fresh rebuilt engine with porting of intake and heads, beefed up bottom end but a not too radical cam.
There are pretty severe misfires at lower RPMs, and vibration, but gets considerably smoother higher up in the RPMs. Top end torque is good, much better than stock. The misfires appear real, given the rough running of the engine, but the plugs look perfectly clean when checked. Exhaust is clean. There is only about 200 miles on the engine so far.
In particular, this is a 3400 built-up block, 3500 heads, 3500 LIM, 3400 UIM. '99 timing chain, CR appox. 9.1, Cam is a step up from stock. There is a slight alignment issue with the LA1 fuel rail, and at first I thought that might have been allowing the injector orings to leak at deep vacuum. I replaced the GM 36 lb injectors with RC 35 lb, which fit better as far as proper angle into the LIM, but did not cure the misfires.
I had a local shop install the engine. When it was first fired up, they said it ran about 10 seconds then blew oil out the oil filter gasket. They put another filter on and it happened again. So I told them to replace the oil pump, which I still have. This time it stayed running, but only if the gas pedal was held slightly open. I drove it 3 miles home, but it ran very rough, a lot of vibration. Now, I also had a billet engine mount (the one near the radiator), put on, so some of the vibration may be due to that.
Originally, there was synthetic oil put in, but I drained it out after about 20 minutes of run time, 3 miles of driving, then changed to Autozone brand regular oil. The first oil was darker, but no visible particles. Second oil change at 50 miles, looked perfectly clean.
After some idling and low speed driving, I thought it was starting to smooth out a bit, but the misfires remained. The power/ torque seems to be excellent, it does better cruising when above 2000 RPM.The last 50 miles it's been getting rougher. I want to believe that there is some kind of ignition or electrical issue, but I need to hear all possible theories on it. It idles like an old Harley lol....
I have scan files with HP Tuners that I can link to if necessary.
Thanks in advance.
Thanks in advance.
