Easiest way to drop compression on 3.4 (1995 F-Body)
Aside from swapping out the pistons for some dished ones I was curious as to how many others have dropped the compression on their motors without major rebuilds. I'm looking to get about 8.5:1 CR for my blower just for safety/reliability reasons
1995 Chevy Camaro :: 60 Degrees of Fury
Got boost? I\'ll have it soon enough.
you can open up the chambers some, thicker head gasket...
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
thicker head gaskets is the easyest way. aluminum head head gaskets are a bunch thicker i beieve and should drop it down a bit.
stock, your motor is only 8.9:1, and you realy shouldnt have much of a problem with it for a low boost setup(around 12lbs). if you go any higher that needs lower compression, id be putting some forged slugs in it, as cast pistons dont like a ton of boost.
