lg8 turbo
  • lg8 turbo
    Hello everyone
    Im new to the forum, but definately not to gettin my hands a little greasy.
    So...i need boost
    Heres what im workin with, and my build plan:
    Gen III 3100 w/aluminum heads
    Basic mods so far.
    Ive got this in the works:
    Full P&P on intake manifold and cylinder heads(doing this myself, have a fully equipped shop in my back yard)
    1.6:1 alum rockers
    ARI cam, lift is 420 intake and 443 exhaust
    OS stainless steel valves..not sure what i want to run here yet...
    59mm MMS TB
    WOT forged pistons...20 over, coated and yielding a 9.5 comp ratio
    WOT Forged H beam con rods...
    Megasquirt for tuning
    4T65e w/HD upgraded diff..
    Now, what i want to know...
    What should i do for fuel, ignition.. valve size..
    I plan on getting a custom turbo manifold and running a t3 .60/.63 eventually..
    Only lookin to boost about 9-11lbs..
    My goal is 330whp.
    Any tips, info, opinions..would be greatly appreciated.
    Money is not an issue for me, ive been blessed with a good job and i have virtually no expenses..
    Yall lemme know!
    I would go with a WOT tech roller cam not the flat tappet you mentioned. Besides the flat tappet cam has less lift than a stock 3100 roller cam unless the specs you posted are with 1.5 rockers. get the matching springs and all from WOT tech too. WOT sells a turbo camshaft too. emails will have them get you everything you need one stop shopping.
    also a t3 turbo is way too small to make 400 hp. you re going to need a t4 compressor wheel to make that. precision has a 5431 for under $800 bucks. that will spool quick on a 3100
    to make 400 crank I say 42 lb injectors should work and bump the fuel pressure. stock ignition is fine and so is stock valve sizes.
    are you using 3100 heads or the gen 2 heads? if gen 2 then you can buy these already ported and save yourself some time.
