T5 won't handle it well. That's what is in this S10, and the second T5 I've run behind this engine is now *very* unhappy. 4 months of driving it regularly, and I don't take it out for burnouts or drag launches every week either. Every time you toe in more than about 40% throttle you can feel every tooth engagement in 2nd gear, and at full throttle the grinding of bearings being loaded too heavy is very loud. It's whining pretty badly at road speeds lately, and the endplay in the case is enough that it decides to jump out of gear while running down the road fairly often. This trans has 78K miles on it, has been behind this engine for 4 months, been to the drag strip once, and mostly just gets driven around town.
The T5 will start to break regularly at the 275HP level...those "500HP T5" ads and cars you hear about...that's a world class case with 2000$ worth of aftermarket gearset and shafts in them. World-class and Non-world class T5's are only rated for 265ft-lbs input torque, even the V8 models. Been there, done that, have the shrapnel scars from a 2nd gear failure in my leg.
It's a shame that GM never put a stout longitudinal manual behind these engines, the T5 is a wonderful box to drive but they just can't take much power. These engines could be a real weapon in a chevette, turbo 3400/3500/3900 and a good transmission, would take a lot of the v6-class sportsman races. So far, the Aisin MA5/R15x/AX15 has been the least modified option I've found so far. Six-Shooter is running a Nissan FS5R30A trans in his car though-which is good for a LOT of power no problems. So there's another option as well.
