So here's the current state of things:
Still on the motor stand.
Oh well. I used some strawberry jam to bond the intake together, it should be fine. Had to strain it first, too many seeds made it not wanna sit right.
Got the water tank nearly done, just a bit of trimming to do to fine tune things, but again...fire extinguisher!
Needed a bit of a trim to fit though.
Never waste stuff like that, it's handy. Yeah, you gotta grind the powdercoat off but so what, it's free metal.
Finished up the fuel feed line, but I still need to bend the return line. Welding 0.020" wall stainless tubing is touchy!
Feedline is 8mm for about 18", but the rest of the truck is 10mm feedline. Return line is 8mm for the whole truck. I am gonna try to find a 10mm feedline tomorrow, when I got to the parts yard. Also need an auxiliary fuel tank and sending unit, I have almost everything needed to dual-tank the truck so I'm gonna do it. Will give me at least 35 gallon tank capacity, maybe 37 gallon, depends on what tank I get. I'll pick the tank with the smallest hole punched in it, the parts yards are savage about fuel tanks. Fixing them isn't a big deal, just takes patience to make sure they're scrubbed and ~90% full of water when being welded back up. Still scares the crap out of me every time I do it though.
