I know this topic has probably been beaten half to death somewhere on the forum... but I am damned if i could pinpoint one about the 3.4l engine:
Summit lists these full roller rockers as working on the GM 3.4l V6 engine. Can this be right for heads that sport the stock 10mm rocker arm studs?
Also... according to this PDF from CompCam, they don't seem make a 10mm Poly-Lock that would not only work on the 3.4l engine with full roller trunion rockers ...but also fit comfortably under the stock valve covers in an F-body car. Does anyone make such a mechanical creature?
If the answer to both questions is NO!... would the above listed full roller rockers work if the 10mm studs were replaced and if the answer is YES! What is the part number of the stud and what are the install procedures/torque(s) required to make it all work. Thanks for any help!
