300 hp N/A carb 2.8 V6 engine
  • #91
    Originally posted by veekuusi View Post
    Okay , I can see your point.
    Usually the most interesting things or parts are in the backgroud of a picture.
    Specially if the photo was taken in a garage or something similar.
    I work as a antenna techician, satellite tv, cable tv .......
    That is an antenna amplifier for apartment building.
    From 50s or early 60s.
    Now that is cool!
    • #92
      I probably have all the parts on hand to repair that. Looks like you need 5 EF80.
      Sent from my KYOCERA-E6560 using Tapatalk
      • #93
        Probably not the best amplifier for modern HDTV-broadcast.
        Ahh, the days when being a cable TV technician involved risk of electrocution
        Current:
        \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
        \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
        \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
        Gone, mostly forgotten:
        \'90 Pontiac 6000 SE AWD: slow but invisible
        • #94
          I remembered this time to put the bolts to the lifter valley.
          To prevent the oil pressure loss.
          I quess , no one except me , needs to know this information.
          Unless,there are other guys ,that are using mechanical lifters in this type of block.
          • #95
            I've remebered about that pressure loss since the first you posted that you had to pull the intake to install the bolt(s) after forgetting about them on one re-assembly. I found it interesting and went out and examined one of my blocks more closely.
            I don't know of anyone else that is running mechanical lifters in their 660, but maybe one day in the future...
            • #96
              I have some old solid flat tappets that fit and will function here, but I decided I didn't need that kind of maintenance. I'll have to figure out what they are though, I only have three of them.
              • #97
                I had Howard's direct lube solid tappets in my 3.4
                '86 Grand National
                • #98
                  Absolutely love your thread. Would to love to see a video of it running.
                  • #99
                    -Chevrolet Lumina 2.8 V6 engine
                    -2 disc Alcon clutch
                    -Chevrolet S-10 pickup bell housing
                    -Sellholm M-47000 "dog box" gearbox
                    • I hope Wot Tech can ship the heads asap.
                      "End of january" went a while ago.
                      • The very much expected Wot Tech heads have arrived.
                        They came to Finland tuesday, a notice came from the customs and I had
                        to pay the tax and duty ($ 500).
                        But I have not yet seen the heads.
                        I can not collect the heads from the customs, I have to wait for the package.
                        The system is so that they deliver the package to my house.
                        Only problem is that they work very slowly at the customs,
                        I would say dead slow.
                        Maybe after the weekend , monday the shipment comes.
                        Everything else is ready in the engine assembly.
                        The mechanical roller lifters seems to be OK,
                        some minor scratches , no big deal.
                        • Holy Moses!
                          The Wot Tech heads arrived today.
                          Wot Tech guys seem to have done excellent work.
                          Expecially the 7/16" rocker arm stud threads look fine.
                          • Good to hear it. What happened to the photos?
                            Grand Prix trans with 3.33FDR
                            • I am sorry to say , but it seems to be so that amateurs here in Finland do better porting
                              job than pros in the USA.
                              I had the new Wot Tech heads checked this week, they seem to flow way less than DIY ported heads.
                              Same flow bench ,Super Flow 600 , made in the USA .
                              I must say , I am astonished!
                              The guy working in the shop says the problem is the valve seat area.
                              The shape in not the best possible. Far away from ideal.
                              The flow is the same to the 7 mm valve lift, but after that the new Wot Tech heads are bad.
                              The exhaust flow is extremely bad.
                              Test comments:
                              Old DIY heads 13 mm : 337 hp / exhaust 75%
                              New Wot Tech heads 13 mm : 208 hp / exhaust 65%
                              • So the "old" is a previously set of ported heads, not stockers, correct?
                                Do you have a set of stockers flowed on the same bench for comparison?
                                That looks like quite a bit of difference...
