Exhaust header flange?
  • Exhaust header flange?
    Does anyone know where to get a exhaust header flange for a 3500 other than milzy motorsports?
      Thank you!
        So I got a chance to look at those and I'm not sure how well it'll work, I can only get the pipe that I want in 1", 1- 1/2", 1-1/4", and 2"...
          You can't get 1 3/4?
          '86 Fiero, 3500, 4-speed
            Not the pipe I'll be using. And I really want to use this pipe for what I'm doing.
              What pipe are you wanting to use?
                The pipe I posted a picture of above.
                  Must be a blocked site, I can't see it here at work.
                  There are plenty of places that sell bends in all sorts of configurations.
                    These are butt weld fittings that I'm using. So it'll be one elbow and two tees then a reducer on the end of the last tee to dump into the crossover.
                      Your limiting yourself by using schedule 10 pipe fittings... Just get J and U exhaust bends in whatever diameter you need and make your own headers completely...
                        Yes I am limiting myself I know. But I really want to make this work I know someone did it. Just not sure who this guy is.
                          that wouldn't be hard at all to make out of 16 ga header pipe.
                            If yiu looked he use one long radius 90° and two tees. That's what I want to do.
                              you can do it that way, but it will either be way big or on the small side. I would strongly recommend header pipe of the right size.
