3.1L+3500 top swap=not possible?
  • 3.1L+3500 top swap=not possible?
    I've seen people say that the 3500 heads dont fit on the old school 3.1L iron head boat anchors... can someone elaborate as to why? I know the 3100 and 3400 tops can swap to a 3.1L but why not the 3500 top end?
    91' Cavalier z24 A3: cai, muffler (no fart can)
    94' Camaro z28 A4: turbo build commencing
    94' Firebird Formula A4: LT1 355ci, cam, stall, gears, bolt ons, tune
    98' Monte Carlo Z34 A4: stock
    07' Impala LT A4: stock
    Post #3.
      so the combustion chambers are larger then the bore if i am reading that correctly?
        Yes.
          so then would I be able to put a 3500 upper and lower intake on the 3400 heads and gain anything over the 3400 intake setup?
            Only the upper with a 3400 lower.
            '86 Fiero, 3500, 4-speed
              3500 upper + 3400 lower is fine on 3400/3100 heads.. 3500 lower has a different port shape and location and won't match up to 3400 heads
                ahh I see, so the best thing to do in this case is to stick with the 3400 intake on the 3400 heads?
                  You can use a 3400 lower and 3500 upper
                    May be a noob question but what would be the advantages of using the 3.4 lower and 3.5 upper on a 3.1? Better flow? Would it hurt fuel mileage? What else would have to swapped to make it work? Throttle body?
