OK so I have an 88 S-10 4X4 that had a Cal emissions 2.8L that spit a crank.
Picked up a 94 camero 3.4L to build. Here is what has been done to motor.
Bored .030 over, Balanced, Hi volume oil pump
This is the ARI cam I used ----
Duration @ .050 - 204in 214ex Duration - 270in 280ex Lift.420in .443ex Lobe Center- 107in 117ex
1.6-1 roller rockers, Molly push rods, Spring, retainer, and keepers from Comp cams on the 94 heads.
Long tube headers with 2.5in magnaflow high flow converter into 2.5in Magnaflow muffler.
Stock 2.8L intake manifold with throttle holes bored out to 1 11/16 and match ported to gasket, 5.7L throttle body with CFM tech adjustable pressure regulator and injector pod spacer. 1 inch "Super Sucker" TB spacer and GM 5325203 45lb injectors @14psi.
I used to build Ford 2.8L motors and they would rev past 6K easy
