ive done a few things on my 86 cavalier 2.8 gen 1 motor. ive put on a complete msd ignition (coil, 6al, plug wires, ect), changed the horribly restrictive stock air intake pipe (it turns a complete 90 degrees before the throttle body) to alumuminum tubing mandrel bent with a k&n filter, and bukped the timing from 10-12 degrees (it realy like that). ever since ive done that (mainly the ignition stuff) it has started running lean. most of the time when im stomping it, my air fuel gauge shows it around the first bar of stoich and lean, and the spark plugs show lean as well. now this is concerning me a bit, so i decided to throw on an adjustable fpr to bump the fuel pressure up a bit. i threw 2lb more in and it seems to help a bit, but not as much as i want. i have also changed my fuel filter and been running injector cleaner through my car every 5 tanks for the past 8 months. i have tried what i can and it still runs lean. i find if i back the timing back down to 8 degrees, its not as lean (high side of stoich) but i do lose power.
im figuring my stock, old 16lb/h injectors just arent up to snuff of what im doing (and plan to do), so im looking for an upgrade. now i know there are a few choices (i know accel makes some) that fit our motors. ive also heard about 5.0l mustang injectors will work. now i know they are 19lb/h, so it would be about right. now are these a direct fit??? i know were i can get several sets for cheap (lots of boosted mustangs in my area), so if they are a direct fit, i may as well try.
any thoughts on this???
