i know the 3500 is better than the 3400 sfi, but would it be worth converting a 3400 sfi to rwd, or is the 3500 significantly better, making the sfi swap pointless?
how much better?
The 3500 has some advantages over the 3400 but it really depends on your power goals and what you want to do with it.
If you are swapping it to RWD it's about the same amount of work for both, the only additional thing is the 3500 needs an external 7x crank trigger. Right now those are pretty hard to come by.
What quantification do you want "better" in? Lbs? 3500 is heavier. hp. 3500 has 201 vs 175 for 3400 from GM. 3500 is Drive by wire vs cable throttle 3400. aftermarket, 3400 block has a lot more. 3500 has piston oil squirters on 5/6 cylinders.
Whats most important to you?Ben
