3.1l ironhead pistons
  • #16
    anyways, back to my last question, does anyone know what my compression ratio will end up being if i was to get the Sealed Power (Fed-Mog) pistons???
    will it still be simular to the stock 8.5:1???
    • #17
      All of the off-the-shelf pistons available (Sealed Power, Silvolite, etc) will be stock specs, so your compression ratio will not change. If you want to bump compression, you will need to go custom, or mill the heads/block more.
      Marty
      '99 Z-28 - Weekend Driver
      '84 X-11 - Time and Money Pit
      Quote of the week:
      Originally posted by Aaron
      • #18
        Stock compression being 8.9:1 on all 3.1L NA engines if I'm right.
        Franz
        1990 Z24-NA 3.1L
        14.72 @ 92.24 MPH
        14.89 @ 94.92 MPH
        The boost is coming....
        • #19
          ok thanx, i guess ill have to wait till i actualy get my 3.1 ironhead and the cam i plan to run, and figure out what i will have for piston-valave clearance before i can figure out how much i will be shaving off.
          id like to get 9.5-10:1, but i dont know if it will be possible to get that high just by shaving the block and heads.
          • #20
            i got them from wiseco through jbody performance
            I Like V660s
            Does Chevy make beer
            ~Jayme~
            • #21
              Lol. Nobody makes forged steel pistons, they would weigh to much and would get way too hot.
              1992 Chevrolet S10
              2.8 v6 tbi 5 speed
              • #22
                I Like V660s
                ~Jayme~
                • #23
                  Where does it say "forged steel?" I see forged, but I don't see steel. And they sure look like aluminum to me...
                  • #24
                    Forged Build Kit Crate Motor 3.1L
                    Federal Mogul Speed-Pro CamShaft (Profile 4)
                    214/224
                    288/298
                    .295/.310
                    .443/.465
                    107/117
                    JBP Custom Billet Steel Forged Pistons (Specify Desired Compression)
                    Sealed Power Forged Application Piston Rings
                    CompCam Magnum or Sealed Power Hi-Revolution Lifters (Hyrdraulic)
                    Clevite or Cloyes Double Roller Timing Chain & Gear Set
                    981 Cast Iron Nodular Forged Melonite Treated Crankshaft
                    Balanced Flex-Plate or Flywheel
                    Shot Peened Stock Rods
                    Custom Colour Choice of engine enamel
                    Basic Block Preperation: Bath, Honed and Bored. ** Additional Heat Treatment & Cylinder wall prep
                    Felpro Full Engine Gasket & Seals Kit
                    Clevite 77 Engine Bearings 'P-Type'
                    Pioneer Head Bolts/Main Bolts (Equivalent to ARP)
                    Walbro 255LPH High Pressure Fuel Pump
                    Dual Coil High Revolution Valve Springs
                    3 Angle valve job
                    Full Balanced on Rotation Assembly
                    Parts can be added or removed to customize the motor to your specs!
                    I Like V660s
                    ~Jayme~
                    • #25
                      I Like V660s
                      ~Jayme~
                      • #26
                        if what they say is wrong then im wrong
                        dont really wanna argue fro 3 more days lmao
                        I Like V660s
                        ~Jayme~
                        • #27
                          Yeah...JBP...a real safe source for accurate information. They also list the crank as a "981 Cast Iron Nodular Forged Melonite Treated Crankshaft". So which is it, cast iron, or forged? What a bunch of idiots.
                          Its simple: the pistons are forged aluminum, and the crank is cast iron.
                          Marty
                          Quote of the week:
                          • #28
                            okey dokey
                            I Like V660s
                            ~Jayme~
                            • #29
                              I would have to believe the pistons are aluminum. Iron pistons havent been used on any engine in eons.
                              Do you have any pictures of the pistons?
                              • #30
                                no pictures
                                i should call wiseco and find out for sure
                                I Like V660s
                                ~Jayme~
