Yes, I have had my heads milled .040 to increase the compression, changed to a cam with more lift and duration, installed roller rockers and built a shallow oil pan. I'm very fortunate in that I have a good friend that is a machinist and I just sent him the manifold, a TBI gasket for the 4.3 and he did it for me. I'm pretty sure it could be done on a drill press providing you are able to clamp it solid and square. If you need a set of Fiero valve covers, let me know, I have 3 extra sets.
Intake questions
If you have all the injection gear, it would give you reliable starting and economical running to just leave it on there.
On a rod, you could always find yourself any old 4 bbl or even a supercharger top cover, epoxy some studs to the upper injection plenum and bolt the intake camouflage to that.....
Originally posted by BillS View PostIf you have all the injection gear, it would give you reliable starting and economical running to just leave it on there.
