Cam bearings and rear plug
  • Cam bearings and rear plug
    Hey guys I got a question, before I put in the new cam, I took a look at the stock bearings, and I can start to see some copper showing, and the bottoms are worn. So I decided I need to put new bearings in. SBC wide bearings will be going in, but I have a few questions...
    1) All the bearings should be positioned with the oil hole at 4 o'clock?
    2) For the rear plug, should I just pound it out, then get a new one to replace it once the bearings are installled?
    3) Installing the bearings, I should start with the back bearing and work my to the front correct?
    4) I thought I had the tool around here somewhere, but I dont. So as for the tool, summit has them for the SBC, and since Im using the SBC bearings, I should get that tool?
    Anything else I should need to know before doing this? I dont know if it matters or not, but Ill be using the 26986 springs.
    Thanks guys
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
    This is what the bearings currently look like:
    350/NV3500 5spd
      Yes you need to remove the rear plug. The bearings go in from both ends. I believe the right position is 4-O-Clock but check the Chevy power manual I cannot remember off the top of my head.
        I don't have to take the bottom end out to do this do I? I'd rather not.
        Sent from my iPhone in some random spot of Texas.
        350/NV3500 5spd
          No you can do it with the lower assembled.. I did mine with my heads still on.
          As they said get a SBC cam too... The newer expansion style ones look like they would work great since the cheaper ones aren't held to a good tolerance so you may have to f with the die's to get them to fit... I know I had to on my cheap setup.
          I put my oil holes between 4 and 5 roughly...
          This is what I have
          Northern Auto Parts is your one-stop shop for all things automotive. Whether you need auto replacement parts or performance upgrades, we have what it takes to get the job done. Check out our site and browse the wide selection of engine, replacement, and racing products we have available online.
          The expansion ones are expensive though.
            Mines not an expansion style either, and the dies are held on by o rings around the rod. I had the dies cone off inside the block once or twice, so it was fun fishing that out of the block.
              I was looking at getting an expansion one, maybe trying to rent one first. It's a big bill to only do it once.
              On the front bearing, are there still the two holes positioned at 3 and 6 or with the SBC bearings are they all positioned at roughly 4-5?
              350/NV3500 5spd
                The SBC bearing will only have one hole. It is all you need but you can choose to add the second hole if you wish.
                  I left just the one and put it at 4:30 position roughly...
