So it looks like my timing chain must have broken. Car was idling fine for maybe 20 min then cut out at the end of the driveway and wouldn't restart. Didn't hear any serious "stuff breaking" noises when it happened, it just died. Cranking sounded funny, tried to see into the oil fill hole, decided finally to just pop off a valve cover.
Comp 26986 Valve Springs
WOT Tech Strip Cam
matching custom length pushrods
everything else stock 2005 LNJ 3400 (Chevy Equinox, transplanted into Pontiac Fiero) maybe 2000 miles on the engine when in the Equinox, another 1000 in the Fiero with stock valvetrain, and less then another 1000 miles with this valve train before something broke.
Worth it to try and open the timing cover and fix what's broken while in the car or is it definitely (probably) screwed so needs to be pulled for a rebuild?
WOT Tech Strip Cam
