True but unfortunately then you can't take advantage of the squeal-free serpentine belt
Decision help for my Fiero - V6/60.
Originally posted by caffeine View PostTrue but unfortunately then you can't take advantage of the squeal-free serpentine belt
Might be able to do something similar to the power steering bracket I made for my 3500, it'd be tight though.Last edited by ericjon262; 02-11-2013, 10:41 PM."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
you can get a 3400 or a 3500. Both bolt to the factory trans and front engine mount.
if you go 3500 you will need custom pistons made, if using your iron heads. This is due to two things. The larger bore, as well as the length of a 3500 rod being longer.
Get a 3400, and rebuild it with the DOHC pistons. Get the heads ported if you want to get that extra bit of power. Otherwise, a nice cleanup of the bowl area and a 5 angle valve job will be fairly decent. Using a stock fiero intake won't allow big power, but at least run a larger tb if you can manage. I know someone used to port the factory throttle bodies. Otherwise look at buying one of those custom trulo intake manifolds.
Buy a larger roller camshaft from WOT here, but make sure you look at the lift and buy the appropriate aftermarket valvesprings. Using the stock roller cam will work too.
I don't know what your horsepower goals are, but a simple rebuild with the higher compression, stock roller cam, minor head porting and intake work, can get you to 200 hp. If thats all you want, then the iron heads will work just fine for you. If you want more while staying naturally aspirated, then I say use the aluminum heads and intake.
I noticed you said you want to keep it looking stock, if thats the case, then a simple rebuild of a 3400 motor with the dohc pistons and some head work will be a good improvement over your current motor. It will probably make around 150 horsepower at the tires.
why put a truelo on it if you want to look stock...? might as well swap the 3x00..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
IMO it would cost less to just grab a low mileage 3400 and swap it whole. Everything about it is better than the Fiero engine and you won't need mods to make up for losing power with iron heads.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
Originally posted by ericjon262 View Postwhy put a truelo on it if you want to look stock...? might as well swap the 3x00...
Sticking with the iron heads and factory intake will keep it looking stock and can make 200 crank hp if done right. Like I said, post your power goals. If its only 200 then iron heads and intakes will work. If you want more, then keep the aluminum heads for the top end. Or keep the iron heads and fiero intakes and if you want more than 200 put nitrous on it or build a turbo setup.
Originally posted by robertisaar View Postmaking 200 with the gen1 stuff compared to the gen 3 will require a lot more compromise to drivability."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Especially if you use the 3400 block so you can use the roller cam, and then put in the higher compression pistons of the dohc. 200 hp is easy then.
Originally posted by bigcheese View PostIt can do 200 crank hp just fine with no compromise of driveability. A streetable cam like a comp or a crane 272, and minor head work, along with headers, and a gasket matched intake can make that no problem.
Or you could make more than that with a bone stock 3400, or even better a 3500.
Personally i'd much rather go fast than have a "stock" looking engine. If it's not in a museum then who cares. (just my opinion)
Originally posted by Superdave View PostOr you could make more than that with a bone stock 3400, or even better a 3500.
go faster and get better gas mileage too. I could see it if it took extensive modification to use the 3x00 heads, but if you use the Fiero timing cover and accessories, it literally bolts in place. all you have to do is re-drill the drive brackets for the aluminum head pattern."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by caffeine View PostUnless he's going for collectors plates the stock look only goes so far. IMO it would be cheaper to reach the power goals with a full 3400 swap.
Also, maybe the OP doesn't want to hack up or redrill any brackets. Lots of fiero owners keep the iron heads because they don't want to have to modify anything. Be it brackets, or wiring harness. Its not always about collector plates or collectability
