HELP! 2.8 or 3.1 block
3400 won't need the external trigger, it's set up just like your 3.1 and even has the exact same crank.
Originally posted by Superdave View Post3400 won't need the external trigger, it's set up just like your 3.1 and even has the exact same crank.
I'd drop in the whole good 3400, much better to start off with than the short block you have now. The 3400 has the correct CPS hole.
Depending on the year of your Beretta you may need a different front mount, daveycav90 on v6z24.com sells them. There are also some other random things you'll need but it's not a hard swap at all.
Originally posted by Superdave View PostI'd drop in the whole good 3400, much better to start off with than the short block you have now. The 3400 has the correct CPS hole.
