So I dropped my 3.4 off at the machine shop today, due to the rod knock in my 2.8.
They're magnafluxing and vacuum testing the heads on Monday, but say they can't check the valve guides without replacing them due to the design. Something about the style of retainer?
Is this true?
Also, should I be getting anything done to the crank to improve oiling?
I have to go .010 under on both bearings probably due to the previous owner's negligence.
As far as the oil pump is concerned, I've read that I must use the pickup tube and oil pan from my 2.8 due to it being a 4x4 motor. Ofcourse I want to go with a new pump, but is there a difference between the 3.4 and 2.8 pumps?
Thanks!
Is this true?
Thanks!
