Hey guys,
I currently have running in my Fiero a 2.8 with a 3.1 crank and rods, .040 overbore Hyperutectic pistons, hastings rings, a crappy camshaft (Pro-Builder Phase 2), set of 1.52:1 roller rockers, and about 8.5:1 compression.
Basically, I didn't do my homework before I rebuilt this thing.
I want to keep the 3.1 crank and rods, and the pistons and rings.
When I had it installed, I never balanced it, I just assumed it was because it was a kit (I assumed wrong). It runs fine, but it literally dies above 4,000 rpms.
I intend to go with an H260 CompCams Camshaft.
This is what I was planning on doing, and please tell me if this is an acceptable solution to my problem.
I want this 3.2 to run well, I hope to get about 170-180 horsepower.
Currently I have an 8.5:1 compression. I read somewhere that I can deck the heads (matched with the intake of course) to something like .020 safely. I was planning on doing about half that, and go with a .010 cyl head shaving (with the intake). I also planned on completely balancing the entire rotating assembly to within half a gram.
Then I would of course compliment it with all the usual stuff (complete 1.52:1 roller rockers with the entire top-end set-up), complete port and polish (mostly already done). I already have the bored out 57mm TB from Darrel Morse, I've got the hogged out exhaust manifolds, ceramic coated, along with the Y-pipe. A borla exhaust (don't have that yet), high output ignition coil, 17lb Accel Pintle fuel injectors, and the Holley 250hp fuel pump.
Does that sound like a plan? Will decking the heads by .010 be a good solid way to boost compression? I have plenty of spare Fiero cyl heads, so I'm not worried about re-using them 20 years from now.
Thanks!!!
Also, if anyone else has any other suggestions, I'd appreciate it.
My ultimate goal for this is to have a GOOD solid running Fiero engine, with as much power as I can squeeze out of it, while still having it look stock.
Oh yeah, this will be mated to a 5-Speed getrag as well..
thanks!!!!!!!!!
Thanks!!!
thanks!!!!!!!!!
