Ok, guys. It's been a while since I last posted. My Turbo Fiero has a stock 2.8 iron headed with TRW flat top forged slugs freshly rebuilt with a custom cam for the turbo setup, so it shouldn't be tired but it's running with low compression. Part of it is my fault.  I gave it hell while I was tunning it and once or twice ran a tank of regular gas and it was knocking with it.
I ran a compression test and all cylinders show mid to high 90 psi, with a little oil compression goes up....sooo, the rings are shot. I'm going to re-hone it and install new moly rings, but I want compression...lot's of it. At least 160 psi, the more the merrier.
I read a thread about using flat top 2.8 slugs with a 3.1 crank by shaving the top of the pistons. See thread here ->http://60degreev6.com/forum/showthre...Engine-rebuild
I have two spare TRW forged slugs to check how much beef they have. Has anyone done it and ran the engine? How was it?
Guys, note I want to get good compression with the least amount of money invested, so don't suggest new forged slugs. I already have the DIS block, DIS 3.1 crank, rings and gaskets it's just matter of getting into it. Once I get it running I'm going to swap to DIS.
What do you think?
What do you think?
