3400/3500 hybrid project
  • 3400/3500 hybrid project
    Hello dont really post very much but decided to let you all in on what im doing. I am going to college for auto tech and am enrolled in a engine rebuilding class this semester. I am taking the motor out tonite and am researching doing the 3500 top swap. my motor has about 160k on it at the moment. i have a tce 65 mm TB to put on it. The mods already done to the motor are egr delet 36ib injectors ported and polished intakes headers and a CAI. i plan on buying the stage 2 3500 heads from wot tech and ported 3500 lower intake. Switching to all arp bolts and studs. and thinking about upgrading to forged pistons and rods. I am having trouble finding the pistons at the moment though. Also trying to decide what cam i should get for it i would evetually like to do a turbo set up but dont have the money to make this into a turbo build at the moment. hoping to rebuild the motor the suspinsion the after that save for the turbo build. I just wanted to post somthing to see if anyone has any advice i will be using the search button alot and already have started just looking for a little input from people that have already done this. thanks in advance to everyone I love this site so much good info and people. also sorry in advance for my horrible spelling and punctuation.
    The 3400 bottom end has a lot of options for compression without going forged. We can get you forged pistons, but I do not really promote going that route unless you really want to use bigger injectors than 36#. Make enough power to warrant 60# injectors and a forged bottom end makes sense. I would spend the money on a good tuning setup and turbo setup. Maybe transmission as well, since those are a weak spot for most 3400 applications.
      My 3400/3500 hybrid has been finished for almost a year now.Still runs flawless and has great power for having a mild camshaft.I have everything from Wot-Tech Heads,Cam,Intakes.
      Ben does great work for a great price in my book..My best 1/4 was 14.169@98.92 But the last time at the strip it was trapping @ 100mph.So im sure 13's are possible.I can race my car and still drive it home, and to work=)
        which camshaft did you go with? and porting?
          I would like to spend the money on a nice turbo set up but i have to dissasemble and rebuild a motor for my class so i was thinking of goin all out. The after it is back in a driving for a while save for the turbo and transmission. What other kind of options are the other than the forged for my 3400 that would work with a boost and without. thanks alot for the response.
            You can do a forged build and run NA until you go boost. Just don't do yourself a disservice and run 8:1 compression thinking you are going to run 30psi. An engine like that would be a dog when not in boost (let alone NA until you got your turbo) and most people run no where near 30psi.
              My cam is one ben designed before the street/strip one he offers now.So it's almost the same camshaft.Heads are street/strip 3500 heads, with comp ported intakes.
              My compression is 9.1 with the stock pistons.
                Okay cool would i be able to use the turbo cam NA until i boost or will i have to swap out when i go to boost? trying to figure out what porting for the heads and what camshaft to buy for the build. Also wondring if i should do the pistons and rods forged or do the rods really need to be forged. I know im not going to run 30 psi ever but a little boost would be nice.
                  If you can afford it, go forged pistons and rods. Better safe than sorry, especially when you start talking about boost. Ben (Sappyse107) would be the one to answer the cam question.
                    Yeah thats what i was thinking and Thanks i will message him. I'm thinking I might just put the street strip cam in and after I have the turbo set up I will switch cams if I really want to. Iv heard people running boost with there stock cam so the street strip has to be better than that atleast.
                    Sent from my HTC Hero S using Tapatalk 2
                      Okay Going to order the heads and cam very soon think Im Going with the street strip cam and the 3500 heads level 3 porting from wot. Cleaning the heads and block on thursday.
                        Excellent choice! You will be happy as the next best power adder after boost/nos is a great port job with performance cam.
                        Consider learning to tune and get the HPTuner package from Ben as well to really make those additions shine.
                          I just purchased an HP tuner for my car I cant wait to be able to use it!
                            Excellent, now you can fine tune all kinds of things like shift points, AFR in PE mode, spark, torque reduction during shifting, shift speed/atf pressure (if using a 4t65).
                            And if you ever have an issue (eventually all cars do) you can log to see what is going on and REALLY helps diagnose problems. Which otherwise may have cost you more by tossing parts at it.
                              i would go with 3.4 dohc pistons, arp studs and go for high cr build with a strip or race cam and be really happy saying you achieved awesome times/power on just motor
