3500 hp
  • 3500 hp
    Just wanting to get an idea of several senerios. How hp/tq could you get with a stock 3500 non vvt and a single cam change? Or cam change and bigger TB, headers? And lastly Head work, street/strip mild porting bigger springs streetable big cam bigger TB headers port matching ?
    Thanks Rick
    It is pretty well documented that a stock 3500 with a big cam mild porting and headers can make solid 300 hp (see Superdave's old 3500 Cavy). But you need to remember that the potential power from a cam change can be heavily dependent on supporting mods; just throwing a large cam in an otherwise stock engine can actually reduce power.
    Sent from my iPhone using Tapatalk
    Matt
      I forgot to add that proper tuning is just as if not more important than the hard parts you throw at a motor.
      Matt
        stock engine. street cam 12 hp, street/strip cam 25 hp, strip cam 31 hp, race cam 40hp.
          real dyno numbers or desktop dyno?
            Considering what i've gotten out of stock 3500's on the dyno, Ben is about right. Supporting mods will play a huge role though.
            my 5 speed Cavalier put down 275 to the wheels with a ported top end, custom ground cam and longtubes. That's a little over 300 @ the crank. Same engine with a little more work and ITB's put down 263 WHP with an auto trans, that's roughly 330 HP on a rough tune.
              Stop talking before i buy a 3500=)
                I wonder what they do if you wind them to 8500 RPM
                  Probably throw a rod....
                    Mine didn't... /oops
                    stock rods are good for 7K ish, i push mine there often.
                      I think I can get to 8K without losing a rod.
                        Go for it.. lol
                          Don't forget to record it.
