ITB...
I can make a set of LIM > ITB adapters if there's interestRIP - 94 GP SE
DD - 95 GP SE
Fun - 91 Mercury Capri XR2 Turbo AWD Conversion
http://www.werbatfik.com
Longer than some ITB setups, sure. Too long? That's a bit subjective, IMO. The Mazda ITB's I was working on developing have an optimal runner length of 14" - we settled for 12" OAL I believe. It depends a lot where you are setting up your powerband. Using ITB's on a stock LIM should give a reasonable amount of usable low end torque due to the long runners and great top end power as well.
Only one way to find out?RIP - 94 GP SE
DD - 95 GP SE
Are you comparing small DOHC ports to push-rod 2v? Where did you come up with 14"?
Also were the runners as large as the 3x00? Sure if you want to compare apples to oranges we work on a lot of BMW's and the ITB runners are never more than a few inches and are making well over 340hp on 3l engines - but that's not a 60v6 either.
ITB's are not new, look at Superdave's build here on the forum.
Eric, what size are those Triumph ITB's? I looked at them a while back to use on an m20 and remember them having quite a large bore - check out the GXSR TB's, there's a few years around 2000-2003 (IIRC) that had throttles that could separate and are popular choices for ITB's in cars due to the fact that that the TB's aren't cast a s a single unit.
Lets define runner length... then i'll go measure mine.
top of the velocity stack to the back of the intake valve? If we go intake valve to throttle plate then mine are the same length as a stock 3500, unless you measure the 3500 UIM's distance from port to TB... which is WAY longer.
I have zero problems with low end torque, and top end peak power is a little lower than my old 3500 UIM. It feels like it peaks around 6500, my old UIM would pull hard past that but it made less power overall.
I've seen superdaves, it rocks!
I think the triumph TB's are 45mm, but I do not have confirmation on that yet."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
from Intake valve to the throttle plate i measured 13.5", my velocity stacks add 3" to that.
97000/13.5 = 7185 RPM peak
97000/16.5 = 5878 RPM peak
If i could trust my dyno graphs i'd point at either one to be correct however they won't use the spark pickup and rely on the roller RPM to calculate engine RPM. I run up to 7K every time and the graphs stop at 6500.
thanks for posting that! thats pretty cool! what size TB's do you guys think I should shoot for?
His TB's were 48mm, his engine displaces .75l/cylinder.
mine is a 3.5 and displaces .58l/cylinder.
I'm thinking about 42mm would be ideal....Last edited by ericjon262; 07-09-2012, 10:19 PM."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
42 sounds good, mine are 45 and work fine though.
you are aware of all the other issues that come with ITB's right? Crappy MAP signal, all kinds of AE tuning issues, vacuum plumbing, throttle shaft misalignment, IAC motor, etc...
don't get me wrong, they're fun and work really well but expect to spend quite a bit of time working out the bugs. I've lost track of how many times i've had mine apart.
BTW, 2% TPS is about 30 MPH on mine VS about 20% on a normal plenum setup.
read my build thread, nothing is a bolt on, until I make it!
Originally posted by ericjon262 View Postthanks for posting that! thats pretty cool! what size TB's do you guys think I should shoot for?
Here is a handy web site for stuff like this.
