I've heard 3x00 lifters are different from V8 lifters, any truth to that?
lifters?
Originally posted by ForcedFirebird View PostYes."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
10-4, I'll measure them when I pull them for my cam swap and post up my findings."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
The OD is the standard Chevy 0.842. So a small block lifter will fit the hole but you need to determine how the oil band will interface with the oil galley and lifter bore limits. You also need to ensure the anti rotation device is compatible.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Yep, same lifter bore.
I dropped some LT-1 lifters into mine to check out the oiling. Not going to work. They're too tall and the oiling hole lifts out past the block.
Bench grinder time
Sent from my HTC One X using Tapatalk 2-60v6's 2nd Jon M.
do the guts from the lifters fit each other? I've got a set of comp "magnum" lifters that I was going to use on my LT1 that are now collecting dust..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Just throw in stock good lifters, and be done with it. I'm speaking from experiance.
If your sticking with stock rockers, go get a set of 10 MM and drill and tap for them while the heads are out of the block.
Originally posted by SappySE107 View PostAre you sure its gonna fit the hole? I can't believe after 10+ years of doing this shit, I wouldn't know that the SBC lifters work for these engines.
The cam bores in the block and the lifter bores match SBC, I use a SBC tool to install cam bearings and know the BBC lifters can work in a 660 when honed to size. The midget racers use BBC lifters, rocker arms and push-rods in their cars. Know that stuff needs block/head modifications, but wasn't 100% on the SBC stuff.
I'd post up the measurements but about a few weeks ago i threw out all my extra lifter parts.
All GM motors use 0.842" diameter lifters. Some Oldsmobile engines had huge 0.921" lifters, which is bigger than Mopar lifters which are often regarded as the classic engines with big lifters that are able to support aggressive cams. Of course this doesn't matter any more since roller cams are the norm.
So if you have the time you may be able to track down a roller lifter that will drop in and either offer better performance through a hydraulic lifter or switch to a solid lifter.
One interesting upgrade might be to see if new GM Ceramic Check Ball lifter guts could be retrofitted into 660 roller lifters. These lifters offer performance over 7000RPM LS motors.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Originally posted by betterthanyou View PostAll GM motors use 0.842" diameter lifters. Some Oldsmobile engines had huge 0.921" lifters, which is bigger than Mopar lifters which are often regarded as the classic engines with big lifters that are able to support aggressive cams. Of course this doesn't matter any more since roller cams are the norm.
