SAFE ZONE?
  • SAFE ZONE?
    hey guys just wondering, i ordered the pistons for the camaro to put in my 3.1L to higher the cp ratio.. m i in a safe zone i dont want it to b to too high what would i have with those piston in the 3.1L thanks if u can answer in the 10's or higher? i forgot the model # or i would give
    Nothing about high compression pistons is overly dangerous. You probably won't be able to run a turbo or a blower, though.
    If you want to make sure nothing goes wrong, check for warped heads, replace or grind the valves, replace the head bolts, and don't use cheap head gaskets.
    450 HP from a Pushrod V6 on pump gas without nitrous? A few intake and exhaust mods, some forced induction, rewrite the laws of physics...
    Hey, it could work....
      Re: SAFE ZONE?
      Depends on the cam you choose. You'll be over 10s for sure depending on cam and head gasket choice 11s or 12s is very easy
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
        alright i m goin to use the stock heads.. and the cam 16-233-6 comp cam 260 H i believe thats the # i dont wanna b to high in compression b/c i dont want to have to run premium gas all the time with the prices if u know wut i mean.. thanks guys, but thats wut i'll b using. if i get in the high 10's or 11 but i dont want close to 12 or over lol
          With the high CR pistons which you have discussed in previous threads, you'd have to run premium all the time. You will be over 11 and possibly close to 12.
