Everyone that I've read that have done them, its been an 8hr job. But that was the direct bolt in. Add probably another 8hr to that for the modification to fit your engine bay.
Headers Headers Headers
ok so can you explain to me if you don't mind, when i said, "why can't the grand am 3400's headers fit on my 95 grand prix 3100?" because i was told that there wasn't enough firewall clearance. but i thought there was more room between my engine and the firewall than the grand ams..
bszopi said,"Add probably another 8hr to that for the modification to fit your engine bay."
so do grand ams have more clearance back there?
its the way the firewall is setup.
the exhaust on an older Wbody goes all the way straight down and then out through the exhaust tunnel.
where as the Nbody goes out on an angle down and then out past the firewall, it is a completely different setup.
brad had a good pic of the diffference of an older L body (same as a Jbody) comparing the NEW (99+) Nbodies.
i have it on my webspace:
Colin
Not really. The rear header will have to be modified. From the looks of it, all three pipes will need to be cut and bent to clear. An exhuast shop (not a chain store mind you) should be able to do this for you. Just don't let them pressure bend the pipes!
