AN fiitting for stock fuel pressure regulator
  • AN fiitting for stock fuel pressure regulator
    Using TCE AFPR Cap on stock Regulator.
    Any way of using an AN fitting on this for braided lines?
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    Search "AN fuel rail" to narrow the search on Summit Racing. I use the stock 3900 fuel rail and got the correct size AN adaptor to use with steel line that snapped right on.
      I am finding lots of fittings that go into the rail.
      However, I am looking for one that will connect to stock Fuel pressure regulator.
      I will keep searching.
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
        I think more of the point of the AN fittings is to allow you to use remote fuel pressure regulators... if your using stock then there is nothing wrong with adapting the AN line to the steel tube that goes to the regulator since that tube shouldn't be the restriction point... Remember that is the return line... so you shouldn't have a problem unless your over feeding the inlet with more flow than the return can support.
          Ya going to have to mod something up I guess.
          This is just for aesthetics for a customer.
          As of April 2
          Injectors: #36 GTPs
          TB: 65mm TCE
