Thought I'd see if I can't pick a few brains on here and try and pick up some pretty cheap HP ideas. I have a 3.1 Isuzu engine and am going to use it to power a replica 1923 Ford roadster that weighs about 1500 lbs. I have a T5 backing it and a 9" Ford rear axle with 4:11 gears. I've installed a Crane 270-2H camshaft and have a set of 1.6 roller tip rockers to install. I've had the intake bores opened up to use the 4.3 TBI and will be using "lakester" style headers (I know I'll give up a little HP with this exhaust, but it attains the look I'm after). I'm wondering how much can you mill the heads before you have to mill the bottom of the intake? I had a 2.8 in an S-10 back in the early 80's and installed a Chevrolet X-11 camshaft and a set of Chevrolet X-11 heads that were milled to increase the compression and it really woke it up. I'm thinking I had the heads cut .030, but I see from the threads on here, that memory might not be correct (its been three decades!). I know that the milling makes the heads farther apart from each other. Does any manufacturer make a thicker intake gasket? I'm just planning on gasket matching the ports and a little smoothing, nothing drastic. How about the 3.4 DOHC windage tray? Is the HP gain worth the price of new main studs and the tray? Also wondering which OEM pan is the shallowest? I've currently got a Camaro pan and would like to get a little more ground clearance and would prefer to swap pans rather than modify the Camaro pan.
Any thoughts that you have would be helpful.
