Yeah, no probs.
I tapped the rear valve cover hole to 1/2" NPT, Didn't even need to drill the hole larger, the tap just bit right in there... Then used 3/4" heater hose to the valve which is right after the cat on my Fiero.
STUPID BRAKE LINE ! blockin my pic... lol.
On my Camaro the valve is in the downpipe. It works pretty much anywhere in the exhaust. The velocity will create a vaccum. my motor was leaking oil out of EVERYWHERE and blowing the dipstick out of it's hole on the Camaro. This fixed all the issues.
I still have the stock PCV valve, and am going to keep it. You should try to plumb the stock PCV so it will pull a little @ idle then once you're WOT it will really draw through the slashcut and close the PCV off...
