Originally posted by 3400-95-Modified
View Post
porting heads...
Originally posted by ericjon262 View PostI agree w/ ben when it comes to nitrous as a power adder, build the engine like N/a, as far as the heads go, now cam on the other hand I've heard makes a bigger deal with nitrous.
I knew what you meant, but in the case of nos, I don't think all out heads are a good idea because it's more of an on-off type system unlike forced induction."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by ericjon262 View PostI knew what you meant, but in the case of nos, I don't think all out heads are a good idea because it's more of an on-off type system unlike forced induction.
Originally posted by ForcedFirebird View PostWell then send us the heads you mentioned and put them on the Fiero motor. We know how much you like dyno time, and you know how much pride we take in our work - let's do it upBoth of them.
I'll keep looking for a set. I know a good set of heads and intakes would make HUGE power on my 3400 cause it has a huge, lumpy dirty cam. 280 / 288 .57X lift. I have no clue what the redline is cause the needle is way past the 6500 tach and it's still making power, noticeable loss under 4000 though, I have to rev it to 5500 to not bog launch on the street for a good launch.
Edit, this in on my Fiero, obviously. Camaro doesn't have traction on the streeet till roughly 90 - 100 MPH.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
Originally posted by Mars View PostI looked at the heads today and they have damage.Both of them.
Edit, this in on my Fiero, obviously. Camaro doesn't have traction on the streeet till roughly 90 - 100 MPH."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
When I had my cam profiled a while ago I was given a stage 3 boost cam IIRC... so that's another one where I wonder if you've learned more since you did my cam profile or if this cam is still a good option to be running... Either way I do agree that I am not entering in the realm of forced induction since I have no positive pressure in my intake so flow is still very important to me. No argument there.
I guess I should revisit my cam profile and head porting choice this winter.
Originally posted by SappySE107 View PostNo way your cam is stage 3 boost. I thought it was done for nitrous, using a lobe off one cam and a lobe off another.
Maybe its the exhaust lobe is from a stage 3 boost cam and the intake was from the stage 3 N/A cam... I don't remember since it's been a while since you changed to the Comp lobes.
As I recall you used what was at the time a NA stage 3 intake lobe with a NA stage 4 exhaust lobe.Matt
It was a 1280 intake and 1331 exhaust If I remember the cam grind numbers correctly.
Well I'll see what she does at the strip this year and make a decision from there on what I'm going to do... Right now my biggest issue was traction over the power so unless I plan on ditching the Nitrous I don't think I really need to change much. Later on I may go for more n/a power and back off on the Nitrous shot.
ok, I'm bringing this back from the dead. I've been working on my Fiero, and I've slowly been gathering parts. I've got a ported set of intakes, a gt 35 turbo, and a recently acquired a bigger camshaft too(224/214 @.050 537/530 lift w/1.5 rockers) . how much do you think having the heads ported would be worth HP/torque wise? if I do it, I'd be having someone who knows do it, not doing it myself.
Edit:
I'm planning to run about 16-20 pounds of boost all out.Last edited by ericjon262; 10-08-2012, 10:50 PM."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by ericjon262 View Postok, I'm bringing this back from the dead. I've been working on my Fiero, and I've slowly been gathering parts. I've got a ported set of intakes, a gt 35 turbo, and a recently acquired a bigger camshaft too(224/214 @.050 537/530 lift w/1.5 rockers) . how much do you think having the heads ported would be worth HP/torque wise? if I do it, I'd be having someone who knows do it, not doing it myself.
Edit:
Stage III port work and you'll get a mighty fine flowing set of cylinder heads.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
