I've got a '01 Impala with the 3.4L, got the car extremely cheap and I'm not looking at putting any real money into it. I already have HP Tuners Pro, and I know you can gain a lot of power just by properly tuning the V8s (LS- mostly). Has anyone done just a tune on these V6s? If so, what power gain did you see? I just don't want to buy more credits and only gain a few HP. The 3.4 in the minivans make 5 more HP and torque than the Impalas, so I can at least gain that, but if that's the max, it's not really worth it to me. This is my daily driver now, and I know that without spending thousands I'm not going to make it a fast car. It just feels SOOOOO slow the first time I drive it after driving my supercharged Cavalier for a few days.
If it would help much, I would install a larger throttle body, the stock one is obviously more restrictive than the air intake hose and the upper intake, but also larger than the valves and runners. What do you think about a larger TB? Do these engines have problems with the TB icing up if the heater is bypassed?
I had also thought about slightly higher ratio rocker arms, but from what I've heard about the camshafts on these engines, I don't think I should add any stress to the valvetrain. What are the opinions of those with experience with these engines?
Can the rev limiter be raised safely and would it do any good? I raised it by 750 RPM on my Ecotec with no internal modifications and have had no problems in 2 seasons of drag racing and 40,000 street miles, and a few people though even raising it by 750 RPM was conservative for the engine. Yeah, I know, apples to oranges... Another thing is that my Ecotec pulls all the way up to the rev limiter, while my 3400 seems to taper off about 500 RPM before it shifts. I don't have a real dyno, I used a dyno app for the iPod, wideband O2 and datalogging to make a pretty good guess at what to change in the tune on my Cavalier. So I don't know exactly where I am from peak power when it shifts, but looking at the dyno sheets I could find online, I think it would keep the engine more in the powerband if I raised the rev limiter and shift points by a couple hundred RPM.
If I do decide to tune it, can the stock injectors deliver enough fuel at the current pressure? Is there a slightly higher pressure fuel pressure regulator that fits in the stock fuel rail? If not, I assume I could just add a low pressure FPR in the return line, say 5 or 10 PSI, and raise the fuel pressure by that much? Does the stock FPR raise the pressure beyond what it does at atmospheric pressure if pressure is applied to the vacuum port?
I also considered water/methanol injection, I built a full system for my Cavalier for about $20 (yeah, twenty $US) and I wouldn't have to modify the controller's program much to add one on my Impala. The pump and injectors were used and free (and I've got enough for a couple more systems). It helps a lot with the increased IAT on the supercharger, but I'm not sure how much on N/A. The websites that sell kits claim big gains on N/A (for example 16 HP on a Mazda 3L) just by bolting on the kit, but I'm not sure how much I believe that.
If anyone has suggestions for other cheap (not necessarily fast or easy) mods that might help with a good tune, I'd love to hear them. I'm an automotive technician, an electronics hobbyist and I'm pretty good at welding and fabricating. Very little is out of my grasp here, I just want to do this cheap because I'm planning on selling this car in the next year or two. I have as much fun building a fast car as I do driving it, so time is not an issue, just money. I know nothing I add will increase the value of the car much, and nothing (or very little) would swap over to the engine I will have in my next car.
Thanks in advance for answers to any or all of these questions!
Jason
Jason
