Throttle body
  • Throttle body
    Will a 3.4 TB fit on a 2000 3100 intake i just wanted to get a a throttle body that was a bit bigger than a stock 95 3100 i bored it out but it was to thin and would only go to 56mm, so i wanted one a little bigger to start with to get a bigger opening.Any suggestions
    1995 Cutlass Supreme 3100 SFI
    Cold Air K&N Filter
    58mm TB
    Dynomax Duel Exhaust with Performance Catalytic Converter
    FFP Underdrive Crank Pulley
    1/4 mile 15.65 at 90.8 mph
    So you have a 52mm TB that was borred to 58mm and the walls are to thin right?
    A 56mm from a 3400 or 00+ 3100 should fit just fine. Or an aftermarket 62mm
      TB
      Yea the most you can get out of the 52mm is 56mm theres just no more meat before you break thru.Anyway i just thought i could get a 56mm out of a 3.4 or 2000 plus 3100 then bore it out to 59mm or 60mm if there is enough wall thickness there.But i just didn't know if it would bolt up.Thanks again or if you know were i could get one of these TB.
      Cold Air K&N Filter
      58mm TB
        Yes, a 3400 TB or on from a 2001+ 3100 will bolt to your engine. Get a used one via http://www.car-parts.com
          RSM racing sells a 62mm throttle body. it is a stock t-body that's board.
          i got one and it really good hope it helps
          2002 Pontiac GrandAm GT1
          3400 v6
          TOG headers
          RSM 62MM T-body
          FFP underdrive pulley
          GRANATELLI MAF
          Ported upper intake
          MSD DIS 4 ignition box
          MSD Wires and coils (pending)
          Venom high flow fuel pump (pending)
            What year Throttle body did they use do you think to think.
            Cold Air K&N Filter
            58mm TB
              dont know what year, but it was probably a 56mm ported to 62mm! i don't know you can check there web sight for more info.
              3400 v6
              TOG headers
              RSM 62MM T-body
              GRANATELLI MAF
              Ported upper intake
