High Flow, Small Body LZ Injectors
  • High Flow, Small Body LZ Injectors
    Does anyone know where I can get a higher flow injectors that fit the LZ engines? From what I can tell they are smaller than the older style injectors. The second big challenge is that I want to keep the E85 capability of the engine. I'm also planning on turbocharging so I'll need higher flow rate then stock.
    Any ideas on fuel pumps as far as whether the new style regulator in pump vs old style two line return fuel pumps are better or worse?
