Originally posted by 95SleeperAcheiva
View Post
How much power can a 3100 make?
I don't know how a 80mm fits let alone leaves Any street-ability
I just got done swapping a getrag 282 into my 96 GPse. Also a 3100v6 SFI.
Be sure to only use a getrag from a w-body. The same transmission, in other bodies, will have a different bolt pattern for the mounts. I found the 88-91 Grand Prix's, especially the McLaren Turbo has the parts you need. The axles won't match though, I believe a 93 (bah I forget the name) will match. I have the link somewhere.
You need the pedal assembly to mount the clutch. That requires the entire dash to come out. OR, like I did, measure-cut-weld-bolt a custom rig to bolt the clutch to the existing assembly. Used 16ga steel, worked great. But the placement must be precise or the Master Cylinder may fail its seal.
The w-body trans mount for the getrag-282 is rare now. I found 1 at rockautoparts, PontiacJeff found a performance mount for $135...then.
If price is not as important, the Getrag 284 is better...imho but the 282 is quite strong from what I hear/read.Last edited by TGP37; 12-16-2011, 02:23 PM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
80mm TB came from an Aurora motor, I adapted it to the 3.5 upper with a classified and top secret, laminated, organic pressed fiber phenolic material that I found in a NASA scrap pile. (A piece of old laminated cabinet, but my description sounds better! :P)
I then removed the throttle plate, bolted it up to the IUM and used a 1" drill mounted sanding roll and ported the IUM, adapter plate, and TB to a seamless match.
And no, it's track only.sigpicHow to make High performance Emissions:
Originally posted by bob442 View PostQFTT
and/or they got a great deal on a 3400 top end and have a healthy 3100 bottom end.
Anyhow, I was surprised to see this newer thread. Yay 3100!
the guy obviously isn't looking to swap his engine. I've seen an estimated 215 out of a Quad 4 GTZ http://rides.superstreetonline.com/r...rolet/beretta/
I wouldn't imagine it being hard to pull that out of a 3.1. seeing as how a stock L82 is 160hp, and an LG8 is 175hp. It isn't hard to get 25hp. Look into aftermarket fuel, intake, and exhaust systems. Bigger fuel injectors can make a huge difference. You could always bore your engine, and throw bigger everything inside. There's a number of things you could do. If I were to make a guess as to what the 3.1 can put out without forced induction my best guess would be 220hp - 240hp. Just a guess, I have no numbers to back that possibility.
