OK guys, I give you full rights to flame me for not swapping to aluminum heads, lol, but it after all is a truck, and I really want to keep the TBI look, and have a roots blower.... No need to tell me how much more powerful your turbo 3400 is
I just wanna do something completely unique in its own class.
Here is the deal, 1986 S10 with a Blown TBI {Fe} Head 3.4.
1) Right now it sits with a GMPP HT3.4 bottom end...
2) I am in the process of adding heavily ported and cleaned up iron heads (the ones that came with the crate), with shaved valve guides for clearance, and cut for viton seals on all 12.
3) Valvetrain is getting completely re-worked... Crane H-272-2 cam, with Comp Cams 1.6:1 roller rockers, and Comp 983-KIT for valve springs, locks, and retainers. This combo will yield me a 0.484" lift on the intake and a 0.512 lift on the exhaust with safe margins in relation to coil bind and spring pressure.
4) Cloyes Double Roller Timing Chain FTW!
5) Serpentine belt swap, and run the blower with a ASP 2.5" 8-rib pulley.
6) Water/Alky Injection to protect the guts of the motor!
7) Holley 400 cfm TBI run on a home-tuned 1228062 ecm off of the original 2.8 TBI code, using Moates stuff and TunerPro.
Headman LONGTUBE headers, with no cat, custom y-pipe, and a 2.5" flowmaster delta 50
I am hoping to pull about 6 psi out of it, which with that cam, and a good tune, and water injection, I should have a really customized 3.4 that can hopefully put down some reliable power...
Lots of pics to come, and this thing should be on the road by the new year!! If anyone has any input or tips for me along my journey of building this thing, feel free to comment!!!!
CHEERS
CHEERS
